Okay, final build, any last words?
Deck: Old Longboard, 1M long
Wheels + bearings: https://www.ebay.com/itm/Blank-Pro-90mm-Black-Longboard-Flywheels-ABEC-7-Bearings-Spacers/143067902765
Trucks:
https://www.amazon.com/Caliber-Trucks-Cal-50°-Longboard/dp/B0742LLPLF?th=1
Motor:
Motor Pulley / Mount: (Need a 15mm motor pulley not a 12mm https://www.ebay.com/itm/303085850966)
Wheel Pulley - (Ask Dickey if he has black cus black is sexier then silver)
VESC - from a lovely friend, no FOC, 4.12
XT90 antispark x 3-5ish
XT60 x 3-5ish
BMS -
https://buildkitboards.com/collections/parts/products/bestech-bms
Controller - Enertion Nano-X, if used. Any reasonably priced recommendations
Batteries: X40 - 10s4p (we gettin that range baby!)
https://ru.nkon.nl/samsung-inr-18650-30q-3000mah.html
LION Charger https://www.amazon.com/EVAPLUS-Lithium-Electric-W15155059014-QCF3601P1A100/dp/B073QKZGT4/
Charging tip from buddy
Enclosure -
Plastic Mold, heated up and molded to shape
Misc -
Loctite
Threaded Wood insert
M4 x 10mm threaded insert:
https://www.amazon.com/uxcell-Threaded-Insert-Socket-Assortment/dp/B07GKVQ4C2
M4 x 16mm screws:
https://www.amazon.com/Prime-Line-9131208-Machine-Phillips-Stainless/dp/B07D5S32CZ/
Spot Welding
Nickel -
Black PVC Heat Shrink Tubing - 180mm
Insulating cardboard paper - or need fishtape reccomendation
Misc -
12AWG wire x 3 feet
https://www.amazon.com/BNTECHGO-Silicone-Flexible-Strands-Stranded/dp/B00TG1TSUC/
18AWG wire x 3 feet
https://www.amazon.com/Electrical-Gauge-Silicone-Cable-Black/dp/B0746HMTPP/
