Hi guys this will be my first build so some heavy critiquing would be appreciated.
2x Motor Dual Motor Mechanical Kit 2x Vesc 2x 5000mAh 5S 25C LiPos Remote Controller and receiver Charger (No idea, help appreciated) Potential Deck?
And I believe the only other things I’ll need are these connectors. 1 - 2. Will I need any other connectors if I’m not planning on soldering?
I’m connecting the two batteries in series so that’s what I use these connectors for. Do I only need one?
Using this calculator I get a speed of 30MPH. I can’t get this range calculator to work if I leave number of parallel cells at 0 though.
I was told by a user on this forum that 25C batteries definitely wouldn’t be powerful enough and would lead to overheating and I would need at least 40C. Dexter from DIYelectricskateboards.com said 25C works fine. Any help?
I’m assuming there is space for two inputs from each VESC on the receiver? I don’t need any adapters or connectors for that do I?
CHARGING SOLUTION: I have no idea how I’m planning on charging the batteries. What would work best to charge them both at the same time? Preferably without having to remove them. (Even though I still have to check on the liPos). Any help would be appreciated.
Also please list your preferred mounting solution of the electronics. So far all I have is the Tupperware method. Is this the preferred method for everyone?
Also is this a reasonable price to pay for the deck? And will it work well in terms of space for my electronics? Should I look for a cheaper/different deck?
One thing I’m not sure about is in the dual mechanical motor kit which I listed, are the plates for mounting the trucks correct? Will these trucks and plates work with the deck?
Also I was told that the older version of this controller and receiver had connectivity issues. Has anyone tried the updating one that I linked?
Also will I need an on/off switch, they are quite expensive off DIY. How do you install them? Where do you plug it.
Will I need a voltage indicator?
Most Important: Will I need to buy literally ANYTHING else which I have not linked here?
Finally, what do you think of the build? Good? Bad? Advice?
Thanks for the help guys <3
