Hello, I have been browsing the forum for about a month gathering information and I finally decided to start my build. But before I start I will need some help from all of you. I have a fairly good idea of what I need, but not completely sure when it comes to compatibility. What i want out of my board is at least a 10 mile (16 km) range and be able to reach a top speed between 20-30 Mph(32 kph). I live in a relatively flat area, so I don’t have to worry about hills. I want to keep this build under $700, and I am confident I can do it. Since you probably have more important things to do I’ll cut to the chase, this is what I had in mind.
Motor: Turnigy Aerodrive SK3 6374 168 kv
Batteries: 3x Turnigy 5000mah 4S 25c in parallel
BMS: 44/48/50.4 12S lipo BMS http://www.batterysupports.com/44v-48v-504v-12s-30a-12x-36v-lithium-ion-lipolymer-battery-bms-p-268.html
Pulleys and belt: Diy’s 36T kegel pulley combo kit diy-electric-skateboard-kits-parts/36t-kegel-pulley-combo-kit/
ESC: VESC from diy’s website diy-electric-skateboard-kits-parts/vesc-the-best-electric-skateboard-esc/
Controller: Enertion Nano-x http://www.enertionboards.com/electric-skateboard-parts/nano-x-enertion-2-4ghz-controller/
Trucks: Caliber II 50 degrees raw https://www.amazon.com/Caliber-Fifty-Raw-Skateboard-Trucks/dp/B00LTPHPNA/ref=sr_1_13?ie=UTF8&qid=1488752513&sr=8-13&keywords=caliber+II+raw
Wheels: Orangatang Kegel Orange (with loaded bearings) http://orangatangwheels.com/kegel-80mm
I plan on building the deck and motor mount to keep costs low. For charging I plan on using a laptop charging port and compatible charger, although have not looked into the charging side of thing yet. Any help would be greatly appreciated.
