Hi all, this is my first build and I was wondering what you think and what suggestions you have.
These are the parts that I have/ that are shipping:
Deck: Loaded Vanguard
Trucks: Caliber II
Wheels: 97mm ABEC 11
I bought these 3 from a shop in NY by the name of Uncle Funky’s
Motor: Turnigy SK3 6374 192kv
ESC: VESC-X
Battery: 36 Samsung 25r cells that I will be connecting in 6S6P
Remote: Wiiciever from @vitormhenrique
Pulleys and Belt: 36T ABEC Pulley Combo Kit
Motor Mount: From @korryh
Charger: ?? I did order a BMS but it isn’t coming for over a month (I only saw after I ordered) so I might just not use it. My plan is to be able to take the battery on planes, so I think I will make 2X 2S6P batteries and 2X 1S6P batteries and possibly connect them through XT-60 connectors, but I would like to be able to charge without opening my board at all, does anybody know how I could do this? Also, correct me if I am wrong, but you are allowed to have 2 batteries over 100Wh and as many as you want under that right? If not, how could I make the battery so that I could take it on planes?
Nop… Your total stored energy will give you range… So volts x amp = total energy… 12s3p is the same as 6s6p… You need same number of cells so its same stored eneregy… But yet 12s gives u more volts = more rpm on the motor = more speed = less heat due to lower current drawn…
So then would there be any advantages to 6S6P over 12S3P? Also, I can program the vesc to limit the speed right? Because I used a calculator and it had me going at 40mph with a 12s battery.
There is actually one advantage to 6S6P…easier charging. You could forego the BMS and balance charge with any 6S balance charger (iMax, Accucel, etc). You can do this in 12S3P too, you just have to wire it more cleverly.
And yes the range should be near identical between the two. I have a 12S3P LG HG2 pack and do 12-15 miles if I’m not riding crazy fast.
How are you charging the battery at 12S, and is there any way that I could still (I didn’t have it completely worked out yetfor 6s anyway, as I didn’t have a solution for charging) make it so that I could take it apart to go on planes?
I think I will buy it then, do you have any idea of how i could make it so that the batteries could be disconnected and reconnected to make the 12s3p battery, but then disconnect to make 3 12s1p batteries?
