Hi guys,
I recently got interested in esk8 building after having withdrawn my pre-order for a Boosted following their battery issues. I ordered what I believe is everything I need to assemble my first build, here are the parts:
- Loaded Vanguard 42" deck Flex 2
- Caliber v2 10" Trucks Blackout (50 Degree Baseplate)
- Kegel 83A (a bit hard but I can’t get my hands on the 80A) with Loaded Jehu Bearings
- DIY 36T KEGEL Pulley Combo Kit (Motor Pulley: 16T Motor Pulley, Belt Size: 265mm 12mm Wide)
- DIY Electric Skateboard Motor 6355 190KV
- Benchwheel remote
- DIY Single Bolt On Motor Mount Set ONLY (Black)
- DIY Motor Mount Type: 63mm Motor Mount
- DIY VESC BLDC Speed Controller
- DIY On Off Power Switch Electric Skateboard
- 40 x LG 18650 HG2 for custom battery
- 36V 10S 60A BMS
- Li-ion Li-Po 42V for 36V 37V 10S 2A Wall Socket Battery Charger
- Bluetooth module for VESC from rpasichnyk
Am I missing anything?
Probably some kind of charing 5.5mm DC female connector…?
Thanks,
Pyt
