Thank you for your comment. I’ll keep my motor and reduce ERPM to 60k. I’ll buy a vesc and mosfet switch. I’ve found only one mosfet switch:
HGLRC-Flipsky AntiSpark Switch Pro 280A for Electric Skateboard (AU$67)
CNC motor mount for motor looks reliable.I’ll get one
Hope no more Hospital bill
Very difficult to find Wheel pulley with more than 40T. 3D printing …
Better use 2 motors with 2.4:1 or 3:1 gear ratio per wheel as I’m planning to have 103mm wheels
Everybody is happy with this 15mm Wide Belts DIY ABEC Flywheel Pulley Kit 265mm 255mm
But my wheels are not Flywheel brand and I’d like to have 15T aluminium / steel motor pulley
3:1 gear ratio
I would like to buy from hobbyking this one
Turnigy Skateboard Conversion Kit Spare Parts - Pulley Set with Belt
And to fit 2 motors (TURNIGY AERODRIVE SK3 - 6364-245KV) I need a widest truck like this one
TRAMPA SKATE style Trucks
It come as standard with re-enforced 9.525mm steel hollow axle which travels the complete width of the 39cm hanger (15 & 1/2 inches). This the lightest ATB steering system on the market…
My 103mm wheels
nah you can fit 2x 6364 sk3’s on a tb218 truck. look on diyelectricskateboards. they’re like $65usd
and yeah that switch will work
but for what you’re buying battery wise (having 6 individual batteries to charge on a hobby charger is a pain) i’d be investing in a BMS. Get a high current rated bms with an eswitch similar to this: (this would actually be the best idea)
http://www.bestechpower.com/333v9spcmbmspcbforli-ionli-polymerbatterypack/PCM-D223V1.html
this way you can charge all your batteries at once
I have a question about batteries. It doesn’t look like Lipo is reliable battery.
I’m going to order a custom made battery pack. I’m looking at 10s4p or 10s5p. I’m not sure about 12s.
What do you recommend?
I’m going to do my first test ride with 3 Lipo battery, but I’m sure that I’ll change it soon.
