Hey guys,
Just started my build.
Based on a mbs comp 95x board.
2x focbox, with 190kv 6374s
I am waiting on pulleys and belts, but have started prototyping the motor mounts today! (only plywood so far :P)
Tom.
Hey guys,
Tom.
Looks nice, but I see a big problem in your design:
Have a great time with modelling and the built it self
What Steve said - you need some way to adjust the belt tension, either by moving the motor, moving an idler pulley, or making the mount itself longer/shorter.
Oh yeah I know, I will cut slots in the final mounts, this was just to test
Another thing to consider is that the mount is a little close to the deck. The motor or the mount may hit the deck while cornering.
You might be right there, I will do some tests tomorrow
Yeah maybe, I would take out the 2 springs, so you can see at full movement
Good idea, will do that tomorrow.
