I completed my build today only to find that I could barely pick up any speed. I cannot even ride my board up my driveway. I am not using a sensored motor in my build, however it does start without a push. I am thinking maybe the ESC is not able to supply enough current to the motor but I am not sure, I realized after purchasing it that it’s a piece of crap from China. My batteries are soldered together with nickel strips and squished together inside my enclosure. Has anyone had similar problems? Is it my speed controller? Battery? I assume it’s not the motor since many people have reported going 20+ mph with the turnigy sk3 245kv. Also my board pretty much has no braking power. I can get going on flat surface to about 10mph but I can barley stop and I have to jump off the board. I am thinking my speed controller is crap but since I have never done this and Mboards isn’t responding to my emails I’m not sure what the problem is.
Dissasemble it right now. That thing is a massive fire waiting to happen.
If you did any research at all you would know that mixing lithium batteries is a catastrophicly bad idea
That speed contoller is not designed to be able to control a motor like that one. This whole build is future bonfire.
I am not trying to be mean, but this is just dangerous. You will burn down your house at some point if you make things like this. Apart from the mixed battery, there is almost no insulation. I see bare wires and uninsulated parralel groups. 1 mistake and you will have another reason it will catch fire.
Also, soldering batteries heats them up to extremely dangerous levels. You shorten their life and you will possibly blow them up when soldering. The lack of safety on this thing is genuinely terrifying. I honestly think its best to dissasemble this and throw away the battery safely.
Just buy a prebuilt and dont burn you house down. I promise at some point this thing will catch fire if you continue using it.
I realize the battery is dangerous and I did do my research. In fact I got the idea from another forum that mixing batteries was OK. https://endless-sphere.com/forums/viewtopic.php?t=75779 I understand mixing batteries, soldering them, etc. isn’t the best idea but I don’t see why it wouldn’t work. This is not my final setup either, I plan on making a different enclosure with safer wiring. However, assuming that the battery works and is just dangerous, it is just the speed controller that’s holding me back?
You can live with 245kv motor. I used it in single drive and get 30km/h on 60% of power.
Your problems from cheap controller. Get vesc from flipsky. Better fsesc 6.6
