Finally finished my first build. Its just a single drive (Racestar 5065) Will look at upgrading to a bigger 6374 motor and even spacing the wheels from the trucks to accommodate dual. The battery is amazing and I can not recommend it enough. Made by Shenzhen Matrix Battery Co., Ltd. Its 10s5p and I was looking at buying a welder and making my own but William ([email protected]) came through with this battery at $220 USD using Samsung 30q cells.
The Motor mount is from good old Boardnamics and its just a 50amp flipsky VESC. The gear system Is 3D printed by IdeaTB https://www.facebook.com/ideatb/ and fitted like a charm.
Used an old Clarinet case as the housing which works a treat if not being a little close to the ground and I had to reverse mount the motor heal side as I had a few rookie mistakes with belt drive. Attached are photos. Runs really well with the belt needing a little better alignment
An upgrade to your enclosure not only improves looks, but will increase the safety of your components (from the ground, water, whatever else) if properly done
As long as you don’t go over any speed bumps, you should be a-ok
