I diced to build a eskate with motor sk3 6374 192kv, 2 batteries 5s1p 20c and maytech vesc (i have it). 16/48t, 83mm wheels
What do you think?
I see that the batteries have bullet connectors, motor too, the vesc hasn’t any conexións( it’s possible?). Can you recommend me which typ of conexions will be ok (keep the bullets and put to vesc too of change everything for xt60 /90)?
Thanks a lot for answers!
I would like to use some anti spark conexións. How many i’ll need? Only one, between battery and vesc? Or all battery’s outputs?
The batteries have bullet 4mm and the vesc any connection. I know that i will have to solder.
I like to change baterries conexion for xt90 but i dont know, buy only one anti spark and put it before vesc or 3 (2 for batteries and one for vesc)?
Just remember, use the male part of the xt90 anti spark on the wire and then the female acts as a key to close the circuit and gouge power. The female key needs to be bridged with wire like this:
But remember that the mere are 2 batteries so the positive and negative of each are going to be connected to make the series connection and then the positive from one battery and negative from other battery is going to go to the vesc and u have to make sure to solder the xt90 antispark to the wire coming from the battery that has the + wire.
