Very clean build man!
Nice to see someone using these new cells.
What’s the total weight of your board?
They seem to perform very good, your 10S2P with 40T will perform as good as a 10S4P with 30Q cells
I’m planning to make a small and light board because mine is also to heavy.
I want to use the loaded kut-thaka deck, ownboard hubs and esc, the battery will be a 11S1P 40T probably. Just to be able to do 10km rides is enough.
The hardest part is shortening the enclosure. Cutting and bonding.
Furthermore, the Evolve enclosure is only 130mm width. That is not suitable for 21700 cells.
Building is easy if you can get the suitable enclosure for your battery pack. The parts used in this build are plug and play. lol
