Max 25mph on a good day
What charger is it
Im going to go with 36 and 16 tooth pulleys. what size belt should I use.
diy-electric-skateboard-kits-parts/36t-abec-drive-pulley-belt-combo-kit/
The belt is included in that kit. A HTD5 265mm should work though.
Can someone recommend a battery indicator?
Hi again Can someone explain how I can incorporate a on/off switch. Should I buy a pre made one or just use an xt90.
Xt90s loop key all you do is cut into the red wire and wire each end to ethier side of the xt90 to turn it on and off when it is in it makes the current go though off makes the positive current go away make sure to buy anti spark
Where do I put the loop key. Also, do I have to make one or are they pre made. If so, can you send a link
I think you have to make it but I am 15 years old and I managed it is only a few solder points
On the positive wire
Ok thanks. BTW I’m 14
Cool nice to see other teens on the fourm
Im 15 as well, here to help if you have questions though I think @SyrusB has answered quite a few .
