THat you should use 2 5s batteries instead or lower kv motor…
Also I recommend you to invest in more reliable VESC like FOCBOX
You did not include remote…
You did not mention gearing…
I made a mistake copying the text.
the plan was to use the 149 kv option with 90mm wheels (i need ground clearance i think?)
also I will switch to 10s battery and probably going to spend the extra money for a focbox.
Also what are the pro’s of using a BMS against a lipo charger?
I have got my board and ordered wheels, because i was afraid there wasn’t enough space for the wheels i went with a pair off 83mm flywheel clones.
I now want to order the rest off the items I need
I think i’ll order this from Build kit boards:
-Mini Remote
-Enertion FOCBOX
-255m Belt 12mm
-Flywheel Pulley 36T / 12mm
-15t 15mm Motor Pulley
-Motor Mount Right
and going to make the Bluetooth module myself later
The rest I aim ordering at hobbyking:
sk8 149kv or sk8 190kv
10s 5600mah lipo
