If the whole pack is 1.9V, most of the P groups are probably 0. If that’s the case, I wouldn’t even bother. I’ve revived a few 0v cells, but it’s rare and their capacity and ampacity goes to shit. 99% of 0v cells I usually toss in the scrap bin for recycling, it’s just pointless most of the time.
Yeah, sometimes popping them on the charger works. Sometimes just connecting a battery + resistor in parallel works. I try to not salvage any cells below 2.4v, 2.2-2.3 if I’m desperate. 1.9 and below are trash imo.
You can try, but it’s tedious and somewhat dangerous. You need a lab power supply. Charge the pack at something like 100mA per cell until 3v (30v 1A for your 10s4p) measuring each group’s voltage often, and feeling for heat. If cells get warm or voltages yo wonky stop – will probably need to take the pack apart at that point to salvage what you can.
If you make it to 3v per cell you can increase current (maybe 500ma per cell) and charge to full, still monitoring heavily. All this will take like a whole day or two.
As the pack gains charge, the chances of a big fire increase.
If you make it to full, you can do some careful test rides. Don’t pull hard and check the pack often.
It’s very unlikely the whole pack is still working, and even if it charges to 4.2v per cell, capacity and power are likely very diminished. And the pack will be hard to keep balanced.
I’d recommend the litokala lii-500 charger. It’s cheap and can automatically do full charge, discharge and recharge cycles testing capacity, internal resistance, with charge rates from 300, 500, 700 and 1000ma settable individually for each of the four slots. This has been the best $25 I’ve spent on recycling wastes batteries.
Makes sense to get a few units if you’re dealing with lots of cells. 5 units will let you test 40 cells in 2 rounds instead of 10 lol. Each round takes like a whole day, right?
I recently had an 11s3p battery stored on a shelf that I discovered had dropped to 5V total. I trickle charged it for a few days and it has now been restored to the full 46.2V. There may still be hope for your battery depending on the circumstances.
as others said,you can try to trickle charge to revive cells but even its successfull cells probably gonna lose big chunk of their original capacity and probably max discharge rate.you can also tore apart one parallel group and test on those thus reducing the overall risk of the process.you can use cv/cc power supply,paralleling dead cells with good cells in parallel to bump the dead cells voltage(its best to do it with resistors in parallel to reduce amp flow)and even tp4056 can be used if there is still some voltage in the cells.
there is another possibility tho.are you sure your cells didnt just popped cid fuse?im not quite sure about 30qs but most of the cells has CID fuses in them,it pops when overdischarge/overheating occurs.if thats the case you can fix that easily.however i think it damages the fuse when you pop it back in so it might not work the next time fuse is needed thus making your cells pretty much unprotected cells.
i would try to revive them but im trying to build esk8 battery from salvage low discharge cells just like my mini powerwalls lol so im not a guy you want to listen to.
