I totally messed up my motor sensor wires and I want to fix that.
Does the sensor cable I’m going to switch to have to be JST-ZH model?
The only one I can put my hands on at the moment is a JST-SH.
Do you mean the sensor wire from the motor itself or the extension wire to (V)ESC (6pin)?
The Maytech motors usually have JST-ZH with 1.5mm pitch, the Vessc JST-PH with 2mm pitch.
(JST-SH is 1mm pitch). Are you from EU? I would have some spares.
Alright, you could just use the JST-PH wire without extension, how long it should be?
I can send you both (JST-ZH and PH 20cm each) as letter by mail for 2€
But why you want to fiddle around with this tiny connectors and extensions? If you use vesc I would solder a JST-PH (2mm pitch) cable to the hall sensor wires of the motor without extension.
Do you know where I can buy or how to fix the extension wires that goes in the VESC ? I burned the wires that goes into the vesc and need to get new connectors to these wires ? Any ideas ?
