could anyone please help me find some Flat ground Cable within EU…
I am trying to have a clean build but running cables from motors to esc is a big hassle. I have seen the teardown of the Boosted Board and i have seen those flat cables that run on the board under the grip tape ( great insulator ) and i have to admit it is an awesome idea.
the only one that i have found up to this moment:
http://www.digikey.com/product-detail/en/alpha-wire/1231-SV005/A1231SV-100-ND/424115
but it is sold in a 30m reel and costs way to much. I need a max on 1.5m for my build…
Any help would be highly appreciated…
thanks mate. Sadly i am yet to find anything within the EU, but as you have mentioned i have found the US based shops or the China based ones. Since it is winter in EU i will happily wait for the cable to arrive. until then i will also have to build my battery.
i consider this thread closed…
thanks for the link. sadly there is no info on that cable…i need to know some amperage limit. Using sk3 6354 motor so i need the cable to withstand at least 20A
Try flex braid from storm power components if you cant find anything… Theyre based in the US though.
They have 12ga equivalent flat braid. I think it was .375"x.03"
thanks for the info. I have found enough us based shops…for which i pay more for the shipment as for the goods, That is why i am looking for one EU based shop…sadly none up to this moment. I have made a purchase from a China based shop of Ebay. Fingers crossed.
need about 1.5 m of 1/4" or about 6mm wide. 1 mm thickness should be the best. As i have seen this kind of flat cable has about 32A resistance when made with AWG36
Thanks mate. Sadly both of the cables are way to wide for my needs. I would have no space on my board to put 3 strips close to each other on one side of truck hangar. Max needed is about 6 mm wide 1 mm thick…
To everybody who has helped with an idea or a link. This is the Result i was looking for. It is not finished but i presume that you will get the general idea. Some electrical tape will be used under the flat cable to be sure nothing will happen and also some epoxy will be used for the bullet connectors. any piece of advice, feedback or questions are welcomed
