Same. Shame. 10c
Mm how is the accelerstiob with those hubs with flipsky esc?? I am thinking to make the same setup. Only 10s. How is the torque,top speed, battery consumption???
Gr sam
Go 10s or try bigger capacitors. Bigger caps have not been proven yet but it would not surprise me that that would solve it. The current caps look tiny.
i am guessing the smaller size of the vesc took its toll on overall performance. But you can also read people having faults with other vesc at 12s foc. I would rather play with gearing/hubs than change my battery to a higher S.
I didn’t really ever expect this esc to run 12s foc. I can’t be the only one. You wouldn’t really expect a HK sk8 to run it, hell people even dispute focboxes should do it even though it’s been proven a thousand times that they can.
It’s a cheap component esc made for 10s.
I noticed this…both their dual 4.20 and single 6.6 use the same 220μF 100V caps. People have been saying good things about the 6.6, while the 4.20 has cutout issues. Why is this? @Kug3lis any explanations?
single 6.6 on their website
dual 4.20
Good find. It might be a mistake on their site. @moon Can you confirm that the 6 has these caps?
They’re same on my dual or FSESC4.20 and FSESC6.6 I heard that caps. will be changed on next 4.20 … Kugelis or Pimousse already advise me to change them on my 4.20s… For same as 4.12 maybe ? (on the right of the pic)
Also seeing many people trying they’re 4.20 under FOCk without issue… Maybe I will give it a try too
Not only those big capacitors, small ceramics and etc Until @BarbaraZ release schematics which she must I can’t tell nothing much
Is it going to work without issues on BLDC?
Your too lucky … can say the same for me …
Sorry it was a question
got over current and over intensity on 10s bldc … I ride during fiew days all good under 20A motor and batt max, then I got faults during downhill braking… I will make more test with higher batt max see if it change the game … some test here
Edit 1st ride : 40A motor max and min / 30A batt max -15 batt min 2nd : 30A // 25A batt max 3th and good but not that powerful : 20A batt and motor max
I made more change 5Amps by 5A itch time, I change setting with Metr.Pro, I just let you know on the main lines
Have you tried setting it below 30a I remember some people have cut outs with maytech vescs when they were set higher than 30a. I can’t remember if that was batt or motor though
Yes, I will try that tomorrow if it’s no more raining here
He’s on 10S. I’m on 11s So far I just got 1 fault on foc
Today I rode my same usual commute path and with 25a I got no issues so far
Worth mentioning, I’m using stock firmware.
Yeah ! glad you could ride it !
I could ride it without issues too, but when you don’t cruise and ask a bit more, be careful! The faults could happen maybe (like it does to me, mostly uphill and downhill when you play full trigger at low speed…).
(I’m maybe a bit misunderstood, cause because English is not that easy for me.)
