One of my two motors does not spin with adequate power unless throttle is set to 100%. The other motor is able to change with adjustments of the throttle. The side with the issue is the “master” side of ESC while the slave seems to be functioning normally.
When the master is configured by itself without the slave, it is able to adjust the throttle properly. Once the slave is configured, it adjusts throttle properly, but the master is only 0 throttle or 100% throttle.
Any ideas? I included a video of the issue below.
