I have a Flipsky Dual FESC 6.6 pro Switch. When using the vesc tool and entering drv8301_print_faults
I get the following for one of the escs:
| FETLC_OC | FETHC_OC | FETLB_OC | FETHB_OC | FETLA_OC | FETHA_OC | OTW | OTSD | PVDD_UV | GVDD_UV | GVDD_OV |
The other one prints no faults.
Using the faults command prints nothing for both.
There is no obvious misbehaviour
Is there someone with the same VESC? Could you test if behaviour is the same?
Version is the Dual Plus Switch Version
Hi,
they already answered, that this is normal behaviour, which would mean, that the DRV Chip is not connected to MCU at all. THis seems like a hardware design flaw then.
On the other hand I also get Overvoltage errors on full throttle with the TB 6380 Motors. I am not sure, if that issue is just due to the lack of power of the vesc and these motors.
