Don’t you get that this esc doesn’t work reliably on 10s when its rated for 12s!!
The topic here is about the Dual flipsky vesc 4.2.
manners review was like “I was finding the sweet spot on 10s where I won’t get lots of faults when I hit the brakes”
I’ve said what I have to say. I told you under what soecs and conditions I have found that it works, and works well. If you want to use it then use it, if you don’t don’t.
I will say this, until you do actually use it you have no business being then voice of disent.
Regarding it’s soecs, it’s works at 12s with 25a motor max, but I didn’t like it. Regardless the stated soecs are correct.
It’s a mid-rand ESC, it does more than I expected given the cost, so your argument about performance vs. a FocBox is just silly given the cost.
Well now, Just imagine theirs someone at the other side of that screen face palming himself for being foolish in his own ways. Live and learn just why don’t I learn
Just imagine, a world without idiots. What if, we die tomorrow? But, this and that. @BlitzI don’t know how much you know but you clearly are a consumer and the focbox is for you. But still trying to drum up shit as to why the 4.20 is whatever you’re calling it. Flipsky is not for consumers of the market. Its for the diy’ers.
With that said, ill take any more of your banter into the matter as bashing and respond accordingly. As it was said by @mmaner already, until you own one and scienve it the fuck out, shhhhhhhhhhhhhhhhhhh.
Or we can do it here. But honestly, all you’re doing is looking for attention. Which is fine. But you do it around certain people and you’ll play with fire. Youve been warned. DON’T POKE THE BEARS
You lose control of the board - no brake or acceleration. But it’ll reset as soon as you release the throttle. On Ack’s firmware you can still hold the throttle and it automatically resets itself.
How the heck you don’t have cutouts while literally everyone else has this issue?
Why would u say “literally everyone else has cutouts” when the OP said his works just fine after he adjusted the settings. I think the main thing is not to run this at 12S.
I have some other buddies building their boards with this, so far no one mentioned about cutouts.
I’ve out around 100 miles on 10s with 30a motor max and zero cutouts, at 40a motor max I get cutouts when I hit it hard, at 60a cutouts every few seconds.
I wonder if it’s a heat thing. One of my buddies who was monitoring his vesc temp reported exceptionally high temperatures even after a very short ride…
