Im Having trouble with vesc tool and cant get both motors to spin ,its eithet one or the other. is there something im missing in wizard .
( sorry im sure this topic has come up before but i can’t seem to find much info on it)
are you running split ppm or CAN?
if CAN , have you got each vesc set as controller id 0 and 1? Have you also got the can bus cables right?
If split ppm, have you removed a 5v rail from one side of the esc?
if you search for these things you’ll find them.
Running can i think . I didn’t think i would need a cable to link both vesc together as it s all on the same pcb ?
i believe you still need to set master and slave on the vesc tool
Ok i will give that a go thanks
