Hey guys, i have a sensored Flipsky motor and as i have everything in front of me it seams i cannot connect the sensor. Flipsky sensor pins dont line up to foxbox, they are much closer together… please help
Or make your own JST-ZH 1.5mm pitch to JST-PH 2.00mm pitch cable/adaptor
So i got the right connection now…but im not sure how to connect the wires… should i match the color or the order???
Is it a male/female adapter (two plugs) Or is it just a 2mm jst?
why you cut it like that? You can just plug the motor sensor in the adapter cable
I didnt buy the adapter…time issue. I bought so i have to wire it myself
Its the 2mm jst, got connectors from amazon
Look on your focbox, there is written which wire need to go to which pin
Okay, i see that. From the top. Its Gnd, h3, h2, h1, temp, 5v… green is gnd, im assuming red is 5v(neg) and i hope everything else is right bc idk lol
Most important is that you get the 5V and the ground right. The sensor order doesn’t really matter. T should be the old white cable.
- Red = 5v
- Blue = A
- Yellow = C
- Green = B
- Black = GND
From their site on another motor and white is the temp sensor. I’ve added a 10k NTC thermistor to my motors to the temp sensor works
h1, h2, h3 are the hall sensors and their order doesn’t matter. Only the order of Gnd, 5v and temp matters
From flipsky website
Okay…so Red=5v, black=gnd, BGY=sensor, white=temp… sound right?
That’s correct
Yep, got it wired up and tested on my board. Ran alright. Foc wasnt quite as great as i had hoped. Not all that smooth… but it programmed or whatever to Foc so thats good enough for now
