don’t forget the heavy drinking. And the inevitable opiate addiction.
Just be sure you can monitor your cells manually and you will be fine. If they get far out of balance you can use a connector like this and manually balance the pack through the balance connector. This is what I use to quickly balance a pack.
what do you use as a charger for single cells?
I guess same LiPo charger, but instead of charging whole pack you charge a single cell
I use a lab power supply when I am at the bench.
You can also use TP4056 module to charge single cell up to 1A. It has a proper LiPo charging curves as opposed to using regular bench CC/CV PSU just by itself.
I’m having the same idea but I’m planning to install an exposed connector on the enclosure itself, this way I wouldn’t have to disassemble the enclosure and BMS to connect the lab power supply.
The lipo checker should give me the readings whenever I need to performance any balance.
Wow, this is a great thread! Thanks for the info everyone and thanks for starting this conversation @chaka. I’ve recently purchased a 10S Bestech BMS with the knowledge that it will add additional protection to the cells due to low voltage monitoring. However, I never really thought of the down side of bypassing the BMS for discharging.
Awesome thread! have been searching through this forum trying to fully understand what i need and potentially don’t need for my build! If this forum didn’t exist I’d be screwed haha!
