Actually yes I have and I do like how they smoke I just hate the weird taste I get from rolling it. Like a menthol taste
I hate menthol. I wonder if itās just the brand you usedā¦ mine definitely didnāt have that taste.
Personally I donāt think something like this is achievable in the DIY community just yet. These massive companies with crazy budgets have only scratched the surface.
Go for it though bro. Iād be very interested to see how you get on!
Yeah Iāve had only two different brands and that was my experience. Plus my wife is very picky. We have a nice piece but sometimes we get $100 oz special and the taste of it is no bueno lol. I just donāt do bongs anymore because I only the expensive glass ones and last year I broke 3 pures and a cheapo so yeah no more bongs lol.
Thatās because they want a back to the Future board. Iām not trying to attempt that. What Iām designing is much less complicated. Letās say the bottom eboard is made of copper. Strong electromagnets repel ferrous metals like copper also electromagnets repel one another. I just have to figure how to achieve voltage regulation so I can control when the board leaves the bottom board and how much force I can achieve. Ok let me finish building a proto and Iāll post a YouTube vid for yāall to see what im trying to achieve. I think this would be an awesome way to achieve suspension.
Lol. I walked out of a shop last week because their bottom shelf was $100 an oz.
I get good nugs for $60 tops.
My cat has broken over $1000 in glass over the past 5 years. I hate cats lol.
Whatās this thread about again? Magnets?
Okay so no Back to the Future skateboard yetā¦ Sad
But except being cool for a project, you need to ask yourself why would you do that ? Using springs with hydraulics is much easier and is assured to work great, maybe even better
Also with such ālevitationā, you need to still be able to use the board, so leaning on the side must be kept And finally, if you manage around the problem of leaning, I fear it might only leads to wobble at low speed, the program trying to correct the vibrations, and small body movements. Or if you make you program to go past the vibration, how can you still control your board with slight ajustement (at high speed for example), because the program will just see that as vibrations
I will error on the side that you are correct about trying to control the vibrations and leaning and from Low speed wobbles with the electromagnets so that it is not unstable. but rt now lets just get it to float above the other board and stabilized. also iām going to build some kind of box that is able to stabilize the two boards as i attach the stabilizers that will hold it together. If i donāt use electromagnets i could go with a permanent float low tech solution but yet leaning will still be something to figure outā¦
I too have seen the matrix. This is how we get farmed
I heard mention of bong waterā¦?
Staying blazed staying paid.
exit stage front
The way i would do it (easy to do, not high tech but functional) is just 2 metal rods on each end of the deck that are attach to the bottom deck and go through the other one, through bigger holes to have less friction
Nerds reporting comments lol
Friends, do you not know?
http://www.arcaspace.com/en/ArcaBoard/features.htm
Itās made from a space engineering firm for a marketing stunt.
I hardly think thats possible since even for a simple thing line the globe in the picture its not too easy to actually place it so it floats but it is also extremely instable. If you push it even a centimeter it will fall off. To make it more stable youd need a lot more power and i dont think youll be able to do that without a cable pulling behind you. The only thing i could think of is if you want to use the magnetic force as suspension and using it with railes to keep it in place
technical problems aside (of which there are many obviously), how the hell do you plan to steer this new fangled air-sandwich of a esk8 ? I mean, you have to lean heel to toe to exert a force on the trucks, creating an arc the wheels will follow (teaching grandma to suck eggs now). You lean into your air gap and what then ?
So this is not happening. Iām pretty sure magnets and batteries underneath them batteries wonāt be good either. Not the mention the motors of the eSkate underneath the floating board wonāt like these magnets and magnetic field either.
Having said that, prove me wrong and show a scaled version.
Hehe bong water. Yuk.
Well thereās the problem right thereā¦ That earth is a globe.
Earth is flat bro.
If the Earth is flat, then why are trampa decks like this:
And not like this:
Check mate, pancake head.
Oh yeah?!? What about the Orrsom
Take that, 'round-y
