I’m getting really weird behavior in FOC mode where throttle causes the board to brake instead of accelerate.
Everything works perfectly in BLDC mode.
After writing an FOC config, while bench testing under no load, throttle causes the wheels to spin up as normal. While riding though, when I engage the throttle it actually causes the board to brake. When I engage the brakes, it also brakes (so it’s not an inverted controller config). Any idea what’s going on?
Flipsky 6.6, stock firmware
Current no reverse with breaks
FOC
Strange that it works in bldc and foc no.
You run your esc via CAN or split ppm?
Did you already go through the FOC motor detection on both again? Maybe it helps just to refresh it.
Check that your remote is fully charged, right adjusted and the fail safe is set right too.
Still don’t understand why it’s in bldc functioning.
For me it sounds more like a connection issue with the remote. Did you try a other remote or position of the receiver?
To be clear, I’m saying that when I have it configured to BLDC mode, it works fine and is totally rideable. That’s why I’m pretty confident it’s not a receiver issue. When I reconfigure to FOC, that’s when it starts braking instead of throttling.
Hi man! Did you perhaps solve it? Yesterday I configured the new Flipsky 6.6. Motors right direction in BLDC sensorless but a lot of rattle at the beginning (I already used these motors at 10s no problem, now 12s and vesc 6.6), so moved to FOC and they spin in the other direction…@Ackmaniac firmware. I will try to swap the motors wires because I tired just by reverse the motor directionninbthebvesc tool. It does the trick but then after acceleration if I brake gently the motors don’t brake but keep spinning really slow, engaging the brake more stops the motors from spin. So weird!
yeah
it happend to me to
my board went from full throttle to full break in a split second and send me flying
I run maytech remote, two maytech 100A VESC and two 6374 motors in FOC, 12s lipo
firs I thought it was my gloves, some how they got stuck on remote
but it happened few times on the same trip
there seems to be direct correlation between applied throttle and brake
i.e. it will reverse the same amount of throttle to brake
I run my board since september and It never happened before
this is serious problem if you like riding at speed
as its give you no time to bail !!!
That’s scary!
I think what you have is a different behaviour than what I meant. In my case if after acceleration I use the brake gently they motors don’t stop but keep cruising at really low speed. In your case seems that there is no too much range between acceleration and brakes. Maybe try to redo the remote mapping. Once I had similar behaviour and then realised that I did the mapping with the remote in slow mode. I am not saying that this is your case but maybe it will help. You can also adjust the braking curve if you use @Ackmaniac’s Firmware
I got over 200 miles on this board probably 100 miles with maytech remote and never had any problems
I’ve instaled bluetooth recently, but this will not cose problems like this ???
I did reset controller settings and added traction between esc
I can set up motors from beginning
but this expierience put me off fast riding until I will fully test it
I wan’t giet to bottom of this so it will never happend again
this board goes really fast and I fell really hard…
