Yep I did!
Usually yes, if they standard pattern. If you want I can measure it out in the evening when i‘m back from work.
A bit late but here you go, the standard pattern for 63xx motor size
Thanks mate, I’m gonna check out these days!!
You can increase the minimum amps from the default 0.1 amp to 1-3 amps it can help smooth out start up without sensors. Still wont be perfect but can make it hesitate less.
Ok, it ain’t a solution, but I can start from standstill uphill!! Thanks for the advice, it’s waaay better… at least I can enjoy my ride till I won’t get motors!
