I’ve started to see more heat sinking options for the FOCBOXs and wondered if it’s a gimmick or is there a real need to keep the FOCBOX vented? I understand that anything with power going to it will heat up, but would it heat up to a point where it could potentially fail?
I’ve got a single FOCBOX. I’ll be changing my enclosure soon and wondered if it’s something I should consider.
If you only pull 10a at 10s then no, there is not much point. However, with higher continuous currents such as 50a+, it can fry. So a Heatsink would be necessary for safe® operation.
@BoostedBuilder I’m only running a 15000mah Zippy LiPo setup at the moment but I’ll be looking to change to Li-ion batteries in the future. I wouldn’t need it right now, would I?
@banjaxxed I was looking at the 3DServisas ones. I’d probably go with the dual fitment one because then I can add the second FOCBOX in when I upgrade from single drive to dual.
