mhm thatd also be surprising as the mount and screws are from @fottaz but ill for sure check that as well when i am home and get back to you- cheers
You’d be surprised. TB’s screws tend to be too long and end up shorting the motor.
My mounts have 10mm bolts, they cannot really touch anything inside
This problem somehow solved itself. Only thing I changed was to charge the battery all the way up, maybe i should have done that to begin with? Anyways, thanks for the help @Jinra !
Hey mate ! Did you have any problem with your build with no fuse ? Im looking for doing the exact same as raptor but on 12S and i won’t put a fuse …any advice for me :)? Thanks !
