I am a totally new guy to this and I just got my first built. I saw some people here not really loving MBoards - unfortunately, I didn’t know there may be an issue and I got all my parts from them. Everything’s working fine so far, hoping it will last.
I am using FocBox Unity, 10S1P Samsung 40T battery, and the direct drive kit from them (not much info on either of the parts on their website).
The motors spec on their website:
- Max Power: 4000W (2000W Each Motor)
- Max Amps: 55A
- KV Rating: 72
- Max Voltage: 12s
- Motor Diameter: 70mm
Battery specs on their website:
- Nominal Voltage: 36v
- Capacity: 4000mAh
- Power: 144Wh
- Cells: Samsung 40T
- Max Discharge: 30a
Can you please help me set correct numbers in the vesc tool? Right now my settings are:
- Motor Current Max 30.39A
- Battery Current Max 15A
- Battery Current Max Regen -2A
- Battery Voltage Cutoff Start 34V
- Battery Voltage Cutoff End 31V
- Max ERPM 80,000
- Max ERPM Reverse -80,000
Much love to anyone who can give me some advice
