It‘s my second build and i don‘t know what’s wrong (I’m not really a tech guy but learned a lot since I’m building my boards.)
I connected and soldered everything as needed on my board and wanted to connect but my unity does not turn on.
Even my second unity i own from my other board does not turn on but did in the other board hours ago.
Setup:
Maytech 6374 motor , Adapter to smaller wire (between motorwire and unity),12s5p battery 30q - voltage ok, checked it with multimeter , original power button (checked a second one , same issue )
Do you guys have any idea why the unity does not turn on? Added two pictures (the one with the board without finished soldering )
Lights in the unity light up when turning the wheels.
Soooo , when i connect power to the Battery (charger) then the focbox starts so it‘s probably a broken bms. Whatever why right?
Strange is that it charges and that I have Current on the cable.
