FocBox Unity Issues
Hello, I am having several problems with my Focbox Unity that I recently purchased. After downloading" the FOCBOX UI application on GitHub, I connected my FocBox Unity to my computer, it shows that it is connected. So I started the configuration of the battery and motors parts, when I try to press the Apply Uptated Config, it appears in clear but never comes back in dark. (I put a picture to illustrate). I updated, the FocBox Unity, I changed ports of connection and I took another computer but in spite of all that. Nothing nor made, I tried to make this configuration by Bluetooth but when I try to connect the phone to the FocBox Unity this one refuses to connect (I tried with two Huawei phones). Here is my problem, if someone has a solution, I’m interested
Click “read current config” first, then make your changes, then click apply config.
Or, use the guided setup, that might be more intuitive.
Thank you, for your advice, unfortunately, when I try the two ways you advise me, it doesn’t change anything, it still doesn’t want to send the information
Any luck this far?
