will the unity work with the AS5047 encoder?
It can but a rework is required similar to other vesc based designs. I also haven’t finished coding in firmware support for motor 2 for encoders, but it shouldn’t be very difficult to do.
Would this throttle curve increase throttle AND breaking when the slider is near zero?
In other words, the graph shows breaking to the left of zero and throttle to the right, correct?
Sorry to belabor this…
Yes, -0 to -100 is the negative range of the throttle. Positive values cause a harder start/stop near 0 and negative provide a softer start/stop near 0 throttle.
The Unity fork of VESC-Tool mobile has the help files excluded as far as I can see. In the original VESC-Tool you will find a lot of info clicking on the ? or HELP. The mobile version for Android is nearly a full VESC-Tool but with a different UI structure. Benjamin also integrated the HELP files into the mobile VESC-Tool to help people find some basic answers. For good reasons he didn’t integrate the throttle curves into the mobile frontend though. I have no clue why the Help files have been stripped from the Unity Fork of VESC-Tool mobile.
If you need answers you can always go to the matching setting in VESC-Tool or VESC-Tool mobile and click on the ? or HELP. You will see that it is easy to find the corresponding settings in the official releases.
X-Axis = throttle value Y-Axis = output value
You can choose polynomial, natural and exponential functions.
Most of the time it is better to leave the throttle curves untouched and use the pos/neg ramping time to soften or sharpen the throttle response. This setting can be found in App Settings >> PPM >> General.
The most important thing that has an effect on the throttle response are the Current settings for Motor Max, Motor max Regen, Battery Max and Battery max Regen. Using symmetric settings for Motor and Battery Currents makes your vehicle respond most linear to the throttle stick. Bad example: Many people have used very high Motor Max Regen settings (-80A) while using very low Battery Max Regen settings (-10A), thinking that their battery can’t handle a short inrush of high Amps. This will result in very very weak brakes at speed which get very very aggressive when you slow down a bit. Users have then tried to compensate that extreme non linear behaviour using the throttle curves, not understanding that they should rather have used symmetric settings for Motor MAX Regen and Battery Max Regen ( eg. -30A and -30A) to resolve the matter. In such a case the curves will not really help to resolve the issue of weak brakes at speed! Conclusion: It is important to have the most relevant settings right before trying to use a second set of “expert” settings that influences the behaviour again. If your Motor- and Battery Current settings cause a non linear response to your throttle input, you start to overlay curves with curves when playing around with throttle curve settings. That is extremely uncontrollable. This is why Benjamin didn’t integrate the throttle curves into the more simple mobile UI.
Throttle curves are not the most useful feature in skateboarding. You can use them to fine tune your setup, once everything else is setup to react perfectly linear. Two shunt designs like VESC 4 and derivates do not react linear to the throttle input by design! Using the throttle curves can make things worse, especially in the range between 60 and 100% throttle.
Anyone test the unity with racerstar motors had an issue with sensor detection on bldc tool wanted to know if that issue carried over
This thread is specifically about focbox troubleshooting, please stay on topic.
The QR Code still points here: https://www.enertionboards.com/focbox-unity-help-support-guide-info/
This page should redirect to your new help desk site here: https://enertionboards.zendesk.com/hc/en-us/categories/360000073116-FOCBOX-Unity
Eventually we will have enough resources to make all elements of our business picture perfect
For now we just have to deal with a blank page.
Seems like the protocol changed, anyone have a link for the source code?
Hi All,
I am having trouble “taming” my new build with 12S4P and 6369 200kv motors. The board has a tendency to throw you off the back if you accelerate too quickly. Maybe I shouldn’t have named it “Hellboy.”
I have fooled around with throttle curves, but also read the post from @trampa carefully when he discusses PPM and Motor / Battery Max / Regen. Currently I am at the default FOCBOX Unity settings of 60 and 30 amps,
Is there a different setting I should try? I need a better understand of what the current settings do and what baseline / best practices are helpful setting up Unity for a custom board.
Thanks in advance
Just getting real simple, what remote are you using, does the throttle have enough throw for you to smooth it out with your finger?
Your setup is relatively beefy, I think most of us just learned to not fall with the power! Probably not ideal
I am using the Hoyt Puck for the remote. I would say it is very sensitive. I am an experienced skater, but for example, yesterday I was going slowly and maybe jiggled the remote wheel a little and wham – on my back. The board can do this at high speed too, although I am more diligent there.
Isn’t there suppose to be 3 different mode on this remote?
Yeah I’d put the puck up there with the better ones based on reviews here.
Just increase the ramping time in the ppm section.
Few ways to tweak your settings,
opinion 1:
lower your current settings. ex: try motor max 50 min -50, batt max 40 min -20
opinion 2:
play with the throttle curve, smooth out the lower portion of the ppm curve with the exponential curve
example:
@johnnyMeduse yes, there are 3 modes, I have been trying that, I tend to end up in mode 3 (fastest) because of hills…
@blasto I will try option 1 fur sure. I wish I had detailed explanations on what those terms mean exactly. For example, where is / what is the PPM section?
On the throttle curve, the suggested curve above seems to push the acceleration problem into faster speeds. Instead of an explosion at 5 miles per hour, now I get one at 20. I think this is what Frank meant by saying the power curve was of limited usefulness.
