Whaaaat no lol. The 2 pin aux port is for a battery meter. Therefore it measures the same voltage of the battery.
To be entirely accurate, the 2 pin aux port reads 1 volt lower than battery.
I think we have the exact same battery LCD, except mine is not working no matter which way I put the wires.
Did you do anything else besides simply plug it in to the 2pin port?
Here is the video
You have blown the LCD fuse. You can repair this yourself by replacing the fuse or just bridging the two pads where the blown fuse is.
do you mean the fuse in the LCD or in the FOCBOX unity? It works fine when connected directly with the battery
The unity has a fuse for the lcd
Look at you. Being an Enertion support even though Jason is being an a$$hat appreciate you being an esk8squad support member.
Haha thanks man. Yea you know it just kills me that all these nice people who supported Enertion by purchasing a board are being plainly ghosted.
I have the knowledge, let me clean up this fuck up of a companies mess.
Do I need to use the switch that came with my unity? I have a torqueboards battery that has an on/off switch integrated into the battery?
What do you mean use the unity switch. You mean the push button that plug into it?
You can semi permanently connect that jst connector with a wire so the unity is always on. And the battery button would be the on/off
Yeah I meant the push button switch that came in the box. Wasn’t sure if maybe the the battery needed to be turned on before the unity. So I just need to bridge the the 2 pins labeled MOM on the switch port?
Yup. That’s how you do it if you want to use a loop key instead as well
When I try to calibrate my remote with the Unity the ppm bar is stuttering and not at all responding to the throttle. Does anyone know why this is happening?
here is a video:
You can see the blue light on the receiver is solid (not blinking) so that means it is paired with the remote.
this is the remote: Amazon.com
Your remote is not binded to your receiver
Your factory just offers flipsky parts… I didn’t say anything about wanting or needing anything?
Looks like I have a sad motor. Does the Unity have the ability to definitively diagnose that or should I get a mate over with an oscilloscope? Pretty impressed with the Unity interface and bluetooth reliability but it’s a bit hard to appreciate it with a shagged motor and not way to get a replacement.
when i do a setup on the unity everything works except when i do a “apply updated config” app just hangs. I get the same thing both on the pc version as well as the android version. FW is up to date. Aiso i get the same thing with the Unity Metr pro as well as the original bluetooth module. any idea what it could be?
I had similar issues with the metr make sure the metr app is disconnected when applying updates
had to my own metr pro firmware update and it works just fine now…thx for pointing me in the right direction.
Hi dear @Deodand by ertion ,
I wait for two items unity ( preorder ) in the last Mail you say shipping in November , but we have Dezember . And the last Mail what this ?
jenson never gif my a answer to my question.Thanks for help my
