So I am new on these forums, and haven’t really been into long boarding until recently so i am kinda a noob. However recently I thought it would be a cool idea to build a long board i could use on campus that folds to fit into a backpack.
I started by testing on some standard 3/4 in ply to see if having a hinge bolted on and standing on it would break the wood ( I weigh about 200lbs). I knew the leverage would be massive and sure enough the plywood couldn’t withstand the force of the bolts and the holes ovaled. Not giving up on the idea i ordered some baltic birch ply in 3/4in which is extremely strong and has many plys. you can find it here I used a large door hinge (this) and bolted it to the bottom of the deck. I had to use 1/4 baltic birch as a riser to make room for the bump in the middle of the hinge. I sanded it smooth, beveled the top edges, applied red stain and multiple coats of spar urethane. you can see the working finished result of that here:
Not being satisfied with just a folding board i came across these forums and decided to motorize it. This is the current part list that im ordering.
motor: diy-electric-skateboard-kits-parts/6355-260kv-epower-motor/
esc: https://hobbyking.com/en_us/hobbykingr-tm-x-car-beast-series-esc-1-8-scale-120a.html
reciever/transmitter: https://hobbyking.com/en_us/quanum-2-4ghz-3ch-pistol-grip-tx-rx-system.html
motor mount: diy-electric-skateboard-kits-parts/single-bolt-on-motor-mount-only/?attribute_motor-mount-type=63mm+Motor+Mount
gearing: diy-electric-skateboard-kits-parts/36t-abec-drive-pulley-belt-combo-kit/?attribute_motor-pulley=16T+Motor+Pulley&attribute_belt-size=265mm+12mm+Wide
battery: 2x https://www.amazon.com/gp/product/B00E6ZG1Z8/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Im going to post updates when the parts arrive and i figure out how im going to mount them. Hopefully ill post a final build price once its finished and other people will be able to use this post for ideas
