Hello I am from Poland so every part that i will order will be from europe , I registered just recently but have been reading some topic for couple of weeks. I have found some parts that i thought i should share with you guys to get your opinion I want to buy simple parts for first build and can improve in future if I will know that this is the thing for me. The main thing that i will want to do with this build after i will complete it is building firefly ( which i found on this forum too ) remote but without the telemetry just simple version with one function to go forward.
Those are the parts that i found:
deck: I bought used longboard and will use deck from it. I have put a link for similar shape of deck to the one that I have.
motor: This is the motor that i choose
battery: Cheap battery that i found 6s.
balance charger: This charger was recommended for the battery that i choose.
ESC: I know the recommended thing is the VESC but for now i want to try the bad way
Remote: This is the remote that i have found on this forum but I’m not sure if it is good option just because I do not have enough experience. It will be replaced with my own build just as I have said in the beggining.
Wheels: I think Orangatang-Kegel-80mm-80a is popular choice so will go with it.
Trucks: The same with trucks so Caliber II
Drivetrain: I want to find DIY Motor Pulley, Wheel Pulley, Drive Belt, The Motor Mounting Plate and Truck Clamping Parts which I can print on 3d printer. Firstly I will try to buy ready made Motor pulley and drive belt + motor mounting pland and truck clamping but want to 3d print as much as I can. I tried to find some 3d projects for those parts but had no luck maybe you guys can tip what should i write in search to find those 3d projects.
I will appreciate every help and will anserw any questions about my build
