Hey, i need some suggestions, I hope somebody can help me Do you think vesc is the best way to go with 7s2p single motor? Isn’t it going to exceed the 60A limit and burn the dvr chip? I’m lightweight but i hills scare me a bit
vesc works best with 10s and even there are people having problems with overheating with a single 6374 motor. on the other hand there are lightweight people with flat terrain, who are using 6s + vesc combo and are totally fine. so it depends… i wouldn´t be able to use a vesc with hilly terrain and 80kg single drive at 7s.
something else…which cells are you using with that small 7s2p?
Yeah, i read those problems with vesc at less than 10/8s and i was a little worried, should i go with the TB 120a esc, even if it’s not sensored? I don’t know which cells are those, @monkey32 made that pack
