Yo dude, I’ve been considering buying the extended range battery for my bboard but can’t help be annoyed on the range only being 14 miles ( realistically 12 ) and the price being around £300 in the uk. I was thinking surly they’d be releasing a gen 2 extended range soon with improved Capacity? Any thoughts?
Cheers guys
Go buy a battery on the forum
There is a really good seller called @Tinp123 he will sell you a battety with twice the range for less then the price
He can also make an enclosure and then you just swap the enclosures and done
Thanks for tag, but I can not help in this case. Boosted uses different chemistry (LiFePO4 vs Li-Ion) and proprietary bms. It is not so easy to upgrade boosted with diy battery.
The extended range battery uses 18650’s the standard range uses A123 Cells
