I had a general question on how a BMS balance charges individual cells.
Given a 10s battery pack, a 10s BMS would have 10 balancing wires.
So the installation would entail connecting the first position balance wire on the first cell, then the second wire to the second cell, etc, all the way down to the end of the pack.
Once connected, how does the BMS know which cell to balance? Would it not see the entire pack as a single circuit?
I may have a fundamental lack of understanding in electronic circuits in general here so I apologize in advance if this question is making you angry…
These ten wires in a 10S set up, or N wires in a NS, create N secondary circuits. The BMS will pump voltage through the entire pack and these N connections simply drain out some voltage from cells that are higher than the rest until you get a balanced pack.
Wish i was home so i could show you a pic of how i wired my new arduino battery monitor.
Basically, if you test - and 10 you get 36v, but if you test - and 1 you get 3.7v, now if you test 1 and 2 you get 3.7v as well, and the same goes for each pair of adjacent pins.
EDIT:
As an example application, if you connect an opto-isolator (led and light sensor) between pins 1 and 2 and another between pins 2 and 3, both opto-isolators will output 3.7v
No, this is not the case because each cell increases the voltage from cell to cell. The diagram you show has some of the voltages shown on it. Each subsequent cell increased the potential by 3.7V nominal value as you add cells, that is why the 10th cell is(should be 37) labeled at 36V. The rest of the circuit after the tenth cell and terminal P is the same potential. This is why you need to get a BMS specific to the number of cells you are using. It knows the expected potential at each cell.
Yes, all cells are one the same circuit
However, because DC current flows only in one direction, the BMS with its balance leads connected to the positive side of each cell or parallel cell group adds up the voltage in sequence and monitors for correct voltage at each sequential cell or cell group isolating from the cells down stream.
i.e.
The current along a closed loop is the same (look up Kirchoff’s laws for more info). To measure currently directly, your ammeter must be wired inline with your circuit (series).
Voltage is measured in parallel (your voltmeter and source have same voltage, but different current). This is why you can measure the voltage potential of each cells simply touching the leads of your voltmeter to the (+) and (-) battery terminals
