I’ve heard the benchwheel remote is good and it’s smaller.
The attraction of small can go out the window in many ways.
hi guys so i have follow those specs: Batt min: -15 Batt max: 30 Motor min: -60 Motor max: 120 Absolute max: 150
Min eRPM: -60000 Max eRPM: 60000
Min input voltage: 8V Max input voltage: 57V
Battery Cutoff start: 21 Battery Cutoff end: 19.6
the board have a lot of torque but it only hiting around 25 km/h top speed. and way i can raise it? thanks in advanced
What is your gearing and wheel size?
runing 16mm 15T timing belt (all the informaion in the start of the thread) 83mm wheels is there a way to solve this with programming the vesc?
15T timing belt doesn’t say anything. I think you mean 15T motor pulley 16mm wide? And what is your wheel pulley?
I don’t think you can get more speed by changing vesc settings.
36T HTD5 from diy electric skateboards and 15T motor pulley 16mm wide
You still use 7s? If so you need more cells
yes still 7s, prefer stay with small slim battery.
Then bigger wheels or different pulley ratio
