Parts gt2b controller tacon 245kv motor tb esc 120amp 12s 12s miami boards/ barjabrti pack 16 by 36t tb pulleys tb motor mount v4 83mm flywheel clones
lets me know what you think parts getting ordered tonight
Didn’t you sell all your parts a couple months ago?
You’re geared for like 45mph. If you don’t want to go that fast or don’t want to blow your ESC, you should probably drop down to a lower voltage and gearing.
yup i bought a new motor a few weeks back and the rest of the parts i need to order
if not 12s can 10s work?
I mean they’ll both probably work to an extent, but you’re sacrificing torque for it and putting your ESC at risk.
Just drop to 14t
i can do 13t and will my esc be ok? the battery has a bms
Shouldn’t be an issue
Use this calculator to find out how many teeth are in mesh. http://www.bbman.com/belt-length-calculator/
Too few teeth and you’re susceptible to skipping.
6 teeth in mesh
phew alright
Looks like 5 if you run 13/14T
This is gonna be epic! Am I building your pack? We talked about it a couple days ago
thats not what it said when i tossed the numbers in hmm…
haha hopefully i can get about 14miles
i think u might i still needed to talk to u tho pm me
hmm any suggestions?
You can get away with less teeth in mesh if you run a wider belt, so maybe go with 12mm or 15mm
12mm it is then
