I was wondering if such an option is possible without damaging the vinyl sticker.
I want to put a vinyl sticker on top of the board and bond it well to the wood, then cover the vinyl with epoxy and put some fine glass frit on top of it preserving some transparency, while keeping grip.
Is it possible/viable?
Maybe somebody knows some glass frit sources in Europe?
How should I extra-bond the vinyl to the deck so it’s not the weakpoint and it doesn’t peel from the wood?
I asked about this. I like sticker bombing stuff.
Was told to put a think clear over the stickers first and let it cure completely. Then apply epoxy/polyurethane and frit.
Interestingly auto suggestions didn’t show it. Oh well. I don’t want the clear coat to melt the vinyl, but I guess I should just use a normal clear coat I used on my board? Aka aerosol.
And 3M adhesive for sticking the vinyl extra good on the board that is?
Yeah i think the epoxy will damage the ink in the vinyl worse than the clear.
And yeah spray adhesive should be plenty to bond the vinyl down.
I’m thinking of doing the same soon.
If i get to it first i let you know any bumps i run into.
I would test some vinyl on some wood first to see the effects. Is there going to be ink on the vinyl because then you have to think if the ink is soluble. I would put the vinyl down then spray it with krylon acrylic spray for a few coats then. Use epoxy or spar urethane.
631 - removable, wall cling
651 - permanent unless you use a scraper and goo gone and swear words, I use this on my Rueger car sticker
951 - marine grade vinyl. Used on boats specifically not to sun fade or corrode. Id go with that to be safest.
I use fine on all of my builds except when I think it would be better with a coarser frit or a customer ask for it. But I will say this wet out the area you are putting the frit sprinkle it on and then let it dry then after it is dried put a thin coat so it locks the glass in between the 2 layers.
