Hi guys, I have a problem with an MT06374-ha-c motor. Magnets got loose and they are scraping inside the motor. I want to glue them back in. Is there any instructional vid I could use to do this? Or maybe some of you guys could tell me how to do it. I want to use J&B weld will it be ok? Thanks for any suggestions. Cheers.
Nah superglue! (Donāt try this at home)
Do you think I need to remove all the old glue? Or I can just put superglue it in the cracs for fast repair?
No donāt actually I was joking I have no idea how to repair
I would think superglue makes sense
Ask it here
Hahaā¦not.
Hi temp epoxy
Donāt use jb weld there are metal parts in it which will move the glue along the magnets and worst on top of the magnet, which will hit the stator later if itās too much.
Like @banjaxxed said, high temp epoxy or green loctite are a good option to glue the magnet back in. Just make sure you donāt switch the polarity when you take the magnet out. I would mark one side, so that you sure it will be the right direction when you place the magnet back.
Thank you man I will do that. Cheers!
I bought this to battle harden but have not yet done the job
https://ie.farnell.com/mg-chemicals/9200-25ml/chemical-structural-adhesive-25ml/dp/2889759
The tech properties seem to lend well to magnet glueing
I use Epoxy to fit the magnet ring if it loose, and Loctite 680 or 638 to put the magnets in place (put some green stuff between the magnets and use your Dremel grabbing the shaft, centrifugal force will help to introduce the retaining compound in place, do it in both directions). I you mess with the magnets polarity like I did once, just download a free Magnometer app for your smart phone, you will see X, Y and Z; use the Y by pointing to the magnet (positive or negative numbers gives you your pole, usually 14 pole set up is NSNSNSNSā¦). Live the bell to 24hr cure, then clean it, to take rests of sticky metal dust, use masking tape, to stick it to the tape. Hope it helpsā¦
A good video and detailed info here⦠https://www.electric-skateboard.builders/t/ice-crusher-16ply-holypro-4w-chain-drive-mtb-4x-6374-170kv-aps-quad-escape-steering-damper/65823/119?u=j95hicks
Thanks guys.
Donāt put JB Weld on magnets ā I found out the hard way it has actual steel in it.
Has anyone hardened your motors like on this vid? My are getting warm ( a lot) and it would be bummer to fry them. Is adding all the āglueā safe?
Thats not my vid and I havent done it before⦠i just remember seeing and made a mental note in case i decided to try it. @Andy87 probably has more insight. I know you dont want magnets to get HOT(being you wouldnt want to touch for more than 10 seconds), i think warm is gonna happen. And as long as you have clearance for motor movement and hi temp glue that wont fall apart at motor running temps⦠i cant think of any reason why it wouldnt be safe.
@DynaWit I didnāt experienced any temperature rise when battle harden the bell. Putting epoxy to the magnets shouldnāt influence that. If you battle harden the windings the motors can get more warm. Iām just in process of doing this on two motors, so I canāt say yet how much more warm they will get. Do you have a temperature sensor in your motor? What is the actual temperature on yours? Till 80 degree Celsius that shouldnāt be an issue as well.
I dropped a magnet this morning on my quad,had to go home slowlyā¦battle Harding time I think
The aps 6384?
Yes I havenāt pulled it apart yet to make sureā¦but feels like it when I free wheel it
