Edit 1: I need to list the stuff I used
-149 kV SK3 motor
-Samsung 25R cells
-A casted 50 degrees Calibers with one hanger replaced for a DIY milled 2034-T351 aluminum and grade 8 bolts
-3d printed riser with led lights
-VESC 4.7
-Aluminum motor mount in 6061-T6
-PETG battery case
-6061-T6 aluminum deck at 3/16" thickness
-Energus Power Solution 75/150 amp BMS
The grooves should work well on wet roads but it picks up so much water that it was the worst design decision I made. I probably could increase the width of the channels to prevent the issue but cannot guarantee it will pick up water.
