Hey Guys, i finally finished my build. Custom 3d printed enclosure, mounted to the bottom of my deck. Took it for a ride outside over bumps and what not and i noticed some of my mounting holes are getting some separation. Can you guys think of a way to synch it down better? Im cool with something that goes around the board and on top. Any thoughts would be greatly appreciated.
Im thinking along the lines of a strap of some sort thats wide and flat
Aluminium flat stock. Just a flat thin/spring like bar you run down each side of the enclosure to keep the bolt holes from popping out. I suggest you cut “slots” rather than holes if your deck is a bit flexy.
Thats a good idea, i was thinking something easier without much custom works. My whole board enclosure battery pack is custom and it took me foreeever designing, building, soldering. I’m kinda tapped out, so i was looking for an easy solution.
I found these straps that seems like they could do the trick:
https://www.amazon.com/Voile-Straps-Aluminum-Buckle-Orange/dp/B072JV5VL9/ref=sr_1_30?ie=UTF8&qid=1544215546&sr=8-30&keywords=rubber%2Bstraps&th=1&psc=1
