So, I have been trying to configure my GT2B controller in the BLDC tool. I set it so that the throttle trim is at 50% and then pulled the trigger and typed in the value and did the same for the brake. But then when I write the configuration the value on the display jumps to like 65% and the throttle doesn’t work, but when I push forwards the motor starts to spins up to full throttle. I can’t figure out what the perfect setting.
I don’t know if the images will help but those are what the pulse width ranges should be.
Two things: 1. On the bench(without load)the VESC will go full throttle with very little trigger. 2. You need to mess with the Max/Min pulse width settings until you are at 50% with no movement of the trigger.
The thing I described in my original post. When I set the min below 1 ms the throttle stops working and when I push it forward (for the brake) it goes full throttle and doesn’t stop unless I disconnect the battery.
I finally got a chance to try this. I set the max and min limits and flipped the switch, but that didn’t fix it. The motor just starts going full throttle and doesn’t stop unless I unplug it.
