I need some help concerning my g2tb. I setup up everything. Motor detection worked. The red light on my gt2b reciever indicates that it is connected, but when I go to settings and select ppm, current no reverse with brake and tick display it stays at 50 %. It doesn’t do anything when I push full throttle or reverse.
I hope somebody can help
do you have the PPM cable from the VESC plugged into the receiver in the correct spot and orientation?
it needs to be in channel 2, with the negative wire on the 3 pin cable furthest to the edge of the receiver.
Even if you have it in channel 1 or 3 (or if the 3 pin connector is in backwards) the receiver will still turn on and connect, it just won’t be able to transmit the information to the VESC.
That’s definitely not normal. Do you mean you have to use a binding jumper every time, and go through the whole process? If so, that sounds like a hardware issue to me.
