I’ve got x2 DIY/TB VESC’s and x2 Polar 6354 190kv sealed motors. Im trying to make HAL sensor cables to to run hybrid mode. I have the JST PH 2.0mm 6 pin cables, but I don’t know what header to use to connect on the motor side nor do I know the wire order.
I’ve searched here, endless sphere and googled my ass off…all I achieved is now I’m more confused then when I started. Can someone diagram the HAL sensor cable and identify the motor side header? Thanks
Kind of, JUST ZH is the header for the motor side, as I understand it, but I need the female header that will couple to it…also the wire pin-out. Thanks
I hope doesn’t sound too stupid, but I use the adaptor from maytech to connect the polar 6355 sealed to the vesc, and just is plug and play. If it helps a picture let me know.
