Hi,
so I’ve got the torque hub 130KV and a VESC using the BLDC tool.
Before I built the housing I connected the motor to the VESC ran the BLDC tool and could just hit “start detection” and I would have my sensors detected.
Now I built the housing and it doesnt work anymore, it always responses
I measured all 3 cables and have the rectangular signal like I know it. I also checked the connection on the board, all cables have connection.
I’m really confused and dont understand that at all. Do I have to make some settings in VESC before I start the detection? It isnt the battery voltage, max input is set to 53V (12S setup), cutoff start to 45,6 and minimum at 8V.
Oh I just realized now you wanted me to measure the Hall Sensors in the FOC tab.
There it just popped a green message “Hall Result Received” and there are now 8 parameters. I dont know tho whether that was succesful or not?
Hello,
I connect the new BLDC motor and sk8 and try to detect the parameters in vesc tool, but detection is failed. Reason: Sensor detection failed. Can anybody help me?
I’ve had that problem many times with the newest VESC tool. One reason could be your battery charger level. Sometimes s low battery will cause a failed detection. Also, are you running 83mm wheels?
If it’s but the battery it wheels, try another firmware to isolate the issue to the VESC tool or motors.
Hello mmaner,
I was tried measure the motor resistance and inductance in FOC Settings with your tool, but detection mesure is bad (Could not measure the motor resistance and inductance). I have the Turnigy D5035-125KV Sensored Brushless Motor from hobbyking and 4 Li-ion Panasonic NCR18650B for testing.
(https://hobbyking.com/en_us/dt6376-14p-sensored-motor-125kv.html)
Can you advise please?
1st, it’s not my tool. It’s built and maintained by @Ackmaniac, I just wrote a how-to (tutorial) about it.
2nd, I’ve never used those motors so Im not sure how I can help. Are you getting a successful BLDC detection? Post some screen shots of the ESC-Tool, that will help a lot.
For what it’s worth, you should probably just return those motors and get the 70kv version. I also had issues with these hubs, same sensor issue you had, as well as efficiency so poor you could actually only scrape 10 miles out of a 10s4p 25r pack. Additionally, when at a standstill, pulling with more than ~30% throttle would make the hubs chatter endlessly
On the other hand… They are A LOT of fun. The unwieldiness makes it interesting lol. I hit my top speed of 40mph with those, but I cant recommend it
