I’ve had my board running for a month now just trying to make it a bit prettier (still using tupperware), I’ve spent past few hours trying to get my mad monkey GT2B mod to work (it’s still not). I got it to bind with the receiver but the throttle does nothing so i thought i’d check the throttle display thing on the BLDC tool, with my wire harness I usually disconnect one of my 5S lipos and short out that connection so when programming the VESC i’m only using 5S instead of 10S.
It’s late and I messed up by plugging my loop key into my spare lipo instead of the the interrupt, there was a spark, the metal connections in the xt90’s are melted and the cell voltages are very unbalanced.
(Loop key on left, LIPO on right)
I guess well over 100A went through it to deform the metal like that
The cell voltages are 4V, 8V, 12.2V, 16.3V, 20.4V
Any advice on what i should do? I’ve put it in a lipo safe bag for now, is it safe to plug into an IMAX b6 if i put a new connector on it? if it did balance would it be safe to use? if not how am i supposed to get rid of it?
