As you can see from the logs, all current and power goes to zero but the duty cycle keeps staying constant, that means the cutouts ocurr while I’m keeping the throttle pressed, of vourse the cutouts are more noticeable on hard acceleration or hard braking.
Check the led when you push throttle. Does it blink red while pushing throttle?
Whatever you do do not run motor detection while this problem is occurring, if you do there is a high chance you will short your motor!
No I mean the led on the focbox. Usually if you push the throttle and there’s a drv error the led on the vesc will stay solid red when the throttle is being pushed. If there was no drv the led on the focbox would be a solid greenish color.
Also if it occurs only under load then the chance of it being a drv error are a little lower as usually it won’t work at all even under no load. Also if you type in “faults” to terminal in the bldc tool, it will tell you your errors as well.
These are not errors. It is the acceleration measurement which get’s recorded when you press on the speed box.
When you start the app you can see the errors of all vesc if they are connected by CAN while reading the data of the master. If you don’t see errors at startup then there are no none. So it is best to restart the app after you experienced the cutouts.
If you can’t find any then it is very likely that your remote has cutouts.
